Problems in using external database with ACS
bburn78
I have configured the external database, SQL Server 2000 to connect successfully with ACS. However, ACS still cannot authenticate me successfully. I am totally lost here. I will really appreciate some help here
Some of my other problems:
1. How do I write stored procedures in my database to communicate with ACS?
Error messages: 1. No users matching, although my table is certainly not empty
Thanks for the help in advance,
Your sincerely,
bburn
Thank you for replying. I tried the sample routine to create a procedure given in the sample documentation. However, it doesn't seem to work. Here's my stored procedure. What's wrong with it?Use Test
GO
if exists (select * from sysobjects where id = object_id('dbo.CSNTAuthUserPap') and sysstat & 0xf = 4)
drop procedure dbo.CSNTAuthUserPap
GO
CREATE PROCEDURE CSNTAuthUserPap
@username varchar(64), @pass varchar(255)
AS
SET NOCOUNT ON
IF EXISTS( SELECT memberID
FROM Member
WHERE memberID = @username
AND password = @pass )
SELECT 0,csntgroup,csntacctinfo,"No Error"
FROM Member
ELSE
SELECT 3,0,"odbc","ODBC Authen Error"
GO
GR
ANT EXECUTE ON dbo.CSNTAuthUserPap TO ciscosecure
GO
It keeps on throwing invalid column names. Any solutions?
Thank you.
