Redistribute Connected vs (Routing) Network Statement
jerry.marsh
It appears from the following text in a Cisco manual
"Routes configured with the connected keyword affected by this redistribute command are the routes not specified by the network router configuration command."
That the REDISTRIBUTE CONNECTED statement is an alternative to specifiying the directly connected interfaces on a NETWORK statement of a routing protocol. And further that networks directly connected to a router with REDISTRIBUTE CONNECTED statement present do not need to be included in the NETWORK statements.
Is this a correct understanding?? Any other implications or gotchas of configuring it one way versus the other?
Richard Burts
You have also posted this same question on the WAN Routing and Switching forum where I have posted an answer. I suggest that we consolidate the discussion on the WAN Routing and Switching forum.
Rick
Rick
Unfortunately, I posted it here first, then realized the other forum was probably more appropriate.
