Reverse SSH not working for Cisco 3750.Plz help.
alexc2010
I have configured the reverse ssh mentioned on the cisco document:http://www.cisco.com/en/US/docs/ios/12_3t/12_3t11/feature/guide/gt_rssh.html#wp1051457.
But now I am running into the issue that When I  issue command ssh -l alex:rotary1 192.38.6.8 from the cli of the router  I’m presented with a password prompt.
I  enter my password and get connected. However at this point when I type, for  example, the atdt command I don’t see any output  displayed.
So I  tried typing command atdt <tel no.> and at the same time ran a debug modem  on a separate session. It was from the separate session I could see the call  been made to the remote device and connected successfully. However almost  immediately the modem debug displays message 0236596: Dec  7 2010  12:18:18.236 GMT: TTY69: cleanup pending. Delaying DTR. At no point do I see  output displayed on the session where I connected to the  modem.
When using telnet to  connect, i.e using the same modem and the same remote device, we have had no  problems it is just with SSH.
Any suggestion on this will be highly appriciated.
Alex.
Phillip Remaker
Which IOS version?  How is the line configured?  Is this an external or external modem?  Sounds like a modem signaling issue.
Philip,
I first thank you for coming forward to help me on this.
I use the 30DM(Digital Modem) Card on the router. I have configured on of this modem  on the PRI card(1/18) to make outbound calls. We use this dailup to cyclades the devices located on our remote office. Hence we loose the main internet connectivity we use this option as a backup.
Show ver:Cisco IOS Software, 3700 Software (C3725-ADVSECURITYK9-M), Version 12.3(11)T5
ine con 0
transport output none
line 72 92
modem InOut
modem autoconfigure type mica
transport input all
transport output all
autoselect during-login
autoselect ppp
line 93
absolute-timeout 60
modem InOut
rotary 1
no exec
transport input ssh
line aux 0
no exec
line vty 0 4
logging synchronous
transport input ssh
transport output ssh
Please let me know is this a bug or anything else. AS the same setup works fine when I use TElnet rather than ssh.
Thanks in advance.
REgards
Alex.
When you say "the same setup works with telnet," what are you doing to connect by telnet?
Can you send a "debug modem" of both the telnet and ssh connections?  I can't understany why they would be different.
Your config looks fine but your software is old.  If you have the ability to install a newer version, that may be useful.  I can try to dig through the several year old bugs, but it will be easier if we start with a newer version.
Hi Philip,
Can you please help me on this.
Thanks in advance.
Alex.
