Route traffic between two organizations/networks and extend VLANs on the same link
Simon Z
Currently I have a single fiber connection connecting two organizations/networks using VLAN interface (SVI) and static routing. Switchs involved happen to be Nexus switches from both organizations. Two networks are independant and have their own Internet access.
On Switch-A from Organization A:
Switch-A# sh run int e1/1
interface Ethernet1/1
  switchport
  switchport access vlan 255
  spanning-tree port type edge
  spanning-tree bpdufilter enable
  no shutdown
On Switch-B from Organization B:
Switch-B# sh run int e1/1
  switchport
  no shutdown
Of course both networks have their own IPs for interface VLAN253. Everything is working.
Now there is a requirement to extend a couple of VLANs (1001 and 1002) from Organization B to A, meaning some machines in these two VLANs will be physically located at A but have IPs from B. Here is my plan: create VLAN1001 and VLAN1002 in A without SVI (non-routed in network A) and convert the access ports to trunk ports:
  switchport
  switchport mode trunk
  switchport trunk native vlan 255
  switchport trunk allowed vlan 255,1001-1002
  no shutdown
  switchport
  no shutdown
SVI for VLAN255 will be continuously used to route traffic between A and B. I want to keep Spanningtree seperated so bpdufilter is enabled.
Is this a viable solution?
It just comes to my ind that you will need to route them but make use of static NAT for the specific servers.
Another solution could be VXLAN but it depends on the devices you use as switches.
https://www.youtube.com/watch?v=YNqKDI_bnPM
