Router 803 Problem
zeusico1984
Hello, i have a problem with a 803 Cisco Router.
> This Router has 4 interfaces Ethernet and the IOS only recogniced one
> Ethernet.
> I don't know if it could be the IOS or perhaps the router is bad.
> Sorry for my bad English.
> Pd: I need a reply as soon as possible
> Hola, tengo un problema con mi Router cisco 803
> Este router tiene 4 interfaces ethernet pero una vez dentro del IOS este
> solo me reconoce una ethernet y 3 puertos BRI.
> NO se a que sera debido ni si es el router el que esta mal o el IOS.
> La version del IOS es la c800-nsy6-mw.bin
> Necesito una reespuesta cuanto antes.
> Un saludo y gracias
paddyxdoyle
Level 6
Level 6
When you say the router only recognises one interface, do you mean in terms on allowing you to apply an IP address to one Ethernet interface?
If so this is the correct behaviour as the four Ethernet ports form a hub. You could connect up to four PC's into this hub and set up DHCP on the router giving you a small network or you can connect the router to a switch.
Also remeber that the ports are 10BaseT so check the speed and duplex settings of the devices you are trying to connect.
PJD
