routing help
mistryj
get Overview:-
1. Routers A, A1 and D are on a class B network
2. Router A in separate building to backup router A1 , both running HSRP
3. Router B and C are on a separate class B network
4. Protocol used running across all sites is EIGRP
5. 10MG connections to Sites A,B &C and 5 MG betwen backup router
6. Bandwidth set to 2MG from backup router A1 to sites B & C
Questions:
1. I have a server in Location A currently pointing to a firewall in location A. I want to be able to server to be re-routed automatically to sites B or D in the event is cannot access firewall in location A.
How can this be done ?
2. Sites A, B and C all have equal bandwidth connections so EIGRP should be able to determine shortest path from A to B and C etc. If however the connection to A and A1 failed and both routers became active how will this affect things since a bandwidth statementment has been placed on links from A1 to B and C?
pdervaux
Could you post a diagram of your network? It will be easier to understand your situation.
Pascal
Please see attached.
AS I see you can use IOS server load balancing, setting the default gateway for the server a router. See this url:
http://www.cisco.com/en/US/partner/products/sw/iosswrel/ps5014/products_feature_guide09186a00800eda88.html
I don´t understand very well your second question.
Good luck
