Routing issue
OneTwoMany
I cannot ping from the 192.168.10/24 network to the 10.10.16.0/20 network, What am I doing wrong?
Current configuration : 843 bytes
version 12.2
hostname hostname
enable secret xxxx
ip subnet-zero
no ip domain lookup
voice call carrier capacity active
mta receive maximum-recipients 0
interface Ethernet0/0
description In
ip address 192.168.1.254 255.255.255.0
no ip route-cache
no ip mroute-cache
half-duplex
interface Ethernet0/1
description Out
ip address 10.10.16.2 255.255.240.0
no ip route-cache
no ip mroute-cache
half-duplex
description In
no ip route-cache
no ip mroute-cache
half-duplex
description Out
no ip route-cache
no ip mroute-cache
half-duplex
ip default-gateway 10.10.16.1
ip classless
no ip http server
call rsvp-sync
mgcp profile default
dial-peer cor custom
line con 0
line aux 0
line vty 0 4
password #$&%^&
login
end
5 Replies 5
are both your interfaces up/up ?
GP
Thank you for responding.
Yes both are up. If I telnet into the router from the 192 network I can telnet to the firewall 10.10.16.1, however I cannot telnet to the firewall from the 192 network.
I think there are two possibilities to consider:
It might be a default gateway problem on the PC. The PC can telnet to the router because it is on the local subnet. But the PC may have a problem getting to the 10.10.16 network because it is remtoe and the PC default gateway may not be correct. How is the PC default gateway configured?
It might be that the firewall does not have a route to the 192 network. The firewall can talk to the router because they are on a common subnet (10.10.16) but does not have a route to the 192 network.
Rick
Rick
The gateway on all the PCs is the internal router interface 192.168.1.254.
If I attempt to ping the inside interface of the firewall does it need to have a route back or will it send the ICMP response back to the outside interface of the router?
It needs to have a route back. The respnse is routed independently. It has no idea which way the request came in.
Kevin Dorrell
Luxembourg
