simple question
rodney.adams
I feel stupid for even asking this, but I'm stuck so here goes. I have a simple point-to-point T1 connection. I have a 1721 on one side and a 2620 on the other. I have the routers talking to each other, but I cannot get traffic from the two networks to pass through the routers. I have a route setup on each of the routers pointing the other way, what am I missing? Any help is appreciated.
16 Replies 16
Agree with the other posters as far as the static routes. There are 2 more issues:
1. ip routing is disabled on router2 (1721)
2. there are no default routes set to access the internet.
I'd suggest:
1. As suggested by others, double check:
# on router1
ip route 172.16.3.0 255.255.255.0 Serial0/0
# on router2
ip route 172.16.4.0 255.255.255.128 Serial0
2. Enable "ip routing" on router2:
XXXXXXXX1721(config)#ip routing
3. Add default static routes for internet access via pix:
# on router1
ip route 0.0.0.0 0.0.0.0 Serial0/0
# on router2
HTH,
Mustafa
Sorry Rodney, I should have spotted it first time round. There was a seocnd problem: you have no ip routing on Router 2. Configure ip routing and it should all start working.
Kevin Dorrell
Luxembourg
