SPAN to monitor multiple VLANs on 2950 for WebSense
dwrscisco
I have configured VLANS on 2950 (48 Ports) running Version 12.1(13)EA1.
the LAN on VLAN1 the default VLAN where I connected the PIX (inside) on port 5 interface and WebSense on port 12.
And on VLAN3 I have connected the interface of PIX dmz1 on port 21.
I have tried the command:
monitor session 1 source interface Fa0/5 , Fa0/21
monitor session 1 destination interface Fa0/12
This command allow the Websense to monitor VLAN1 clients but it does BLOCK sites, i.e., it is only monitoring without taking action
at the same time I cannot pnig the Websense server
BUT when I try the command:
monitor session 1 destination interface Fa0/12 ingress vlan 1
this command it monitors and action or blocks sites on VLAN 1 only and I don't see clients from VLAN 3
and I am able to ping the Websense server
Would anybody please advise how can I monitor multiple VLANS with SPAN and allow the Websense server to action the received traffic, i.e., block unwanted URLs.
aashish.c
Level 4
Level 4
When you enable ingress vlan for a destination port, the virtually it becomes a member of vlan 1 and stop seeing clinets of vlan 3. in this case you can setup 2 span sessions each for a vlan and make 2 destination ports and do all the things.
I understand that it might be difficult for you to arrange 2 ports for capturing traffic but I think this is the only way to accomplish this.
Aashish C
Hi Aashish,
I have tried to create SESSION 2 between the system returned an error that "This Platform Support One Session only"
However, thanks for the info, currently I am waiting a response from Cisco Tech, which I hope they solve the problem.
Shamsan
You need to sue SESSION 0 as you second session. then you will not get this error messages. 2950 will support 2 SPAN sessions 0 and 1.
Kindly update after doing this...
Aashish
