11-13-2002 09:58 AM - edited 03-02-2019 02:51 AM
I have a customer who wants to connect Nortel equipment (8K) to 3548 Catalyst.
First problem: we are not able to see the MAC addres on 3548 port (we have tried also fixing speed/duplex ). So we have no IP connectivity for this equipment.
Second problem: Trying to define static mac with command:
mac-address-table static 0004.dc99.6bf4 FastEthernet0/3 vlan 20
Reviewving the show mac inter fast0/x , the mac above appears on all vlan 20 ports...but, this is not the behaviour needed.
Also, when a clear mac is made in order to clean the mac table, the comand mac-addres-table disappear from running config.
Any help should be appreciated??
11-15-2002 12:30 PM
Not quite enough information here...is there an ip address assigned on both switches, what VLAN? are the cables used to connect these two devices straight-thru or crossover? THe mac address will not show up (usually) until an arp is sent. Once the arp is sent, the mac-address-table can be populated. Provide the rest of the information, and I will attempt to assist you...
11-19-2002 03:26 AM
Finally it was a Passport 8600 and customer wanted to connect the two supervisors to a Cat3548.
It seems that all is working fine if port is fixed to 100 full.
Thanks .
