01-24-2023 01:02 AM
Goodmorning,
I have a problem to configue the distribution unit shown in the attach.
I have to configure the interface (actually a port channel) to the firewall, that allow any multicast.
Could you suggest me the right commands that have to be performed?
I have already tested if i disable the IGMP on the distribution unit the traffic flow to the 3th party switch, but it shouldn't be the solution.
Tnx everyone
01-24-2023 01:03 AM
01-24-2023 01:49 AM
what devices are involved here ? You talk about a 3rd party switch, what brand/type/model is this switch ? And what about the rest of the topology, are these Cisco devices, and if so, which models, and which IOS (or ASA if you have those) versions are you running ? Best to post the full running configs of all devices involved.
09-30-2024 11:15 PM
I usually use the command configure igmp snooping vlan <vlan_name> static group <multicast_address> <port_list> on Extreme devices running the EXOS operating system; this is the third-party device I am referring to in the example.
