Strange Print out using Terminal Server connection
edwiwong
To print a job from HK to SG, I have a server with it's serial port connected to line 1 of a Terminal Server 2509 at HK end. The Line 1 is configured as follows
line 1
location "Hong Kong Test Printer"
exec-timeout 0 0
no activation-character
autocommand telnet 10.x.x.x 4034
transport input all
escape-character NONE
stopbits 1
flowcontrol software
through our company intranet, the job is passing to SG. At SG end, there is another terminal server 3620 with line 34 connecting to a printer.
The configuration is of that .
ine 34
location "Printer for HK"
exec-timeout 0 0
transport input all
However we got some problem when users passes print jobs to SG, the printout is so strange that they sometimes got the same line printing twice. However most of the time is running smooth. We have changed the printer, the cable and upgrade the IOS but no enhancement.
I have checked the config. Show line 1 in HK and show line 34 in SG.
There are some difference with
1 stopbit in HK
2 stopbit in SG
Special Chars:
Escape is none in SG
Escape is ^^X in SG
Please kindly help on this~!! Thank you very very much.
ebreniz
Level 6
Level 6
I think this can be a bug (CSCdk57206),when your using 2500 for printing over asynchronous lines by using software flow control, large numbers of overruns may occur. Have you tried using an IOS version above 12.1(1). This might solve your problem.
