Switch Problem
heatonj
Hi ,
Can any one help,
I just trashed a cisco 3550 switch with a power out while deleting the IOS. So now i have no IOS on the unit. When i turn it on i get the switch> prompt. How do I get an IOS onto the unit when it doesnt have an IOS on already??
thanks
Paul
deilert
Level 6
Level 6
If you are getting the
switch>
prompt you have an image it just sounds like tou have no config .
Can you paste in a sh version , I just think your config register is set to ignore NVRAM.
you can do a sh start to see if the config is in NVRAM . If it is do a copy start runn ,
It should be set to 0x2102 Not 0x2142 .
