Tc in Frame-Relay Traffic Shaping
amlendu_kumar
In one Cisco document maximum value of Tc possible is 125 Msc "Time interval over which Bc or (Bc+ Be)
bits are transmitted. Tc is calculated as Tc =
Bc / CIR. The Tc value is not directly
configured on Cisco routers. It is calculated
after the Bc and CIR values are configured.
Tc cannot exceed 125 ms."
But another example has Tc of 250 Msc
"map-class frame-relay cisco
frame-relay cir 64000
frame-relay mincir 32000
frame-relay adaptive-shaping becn
frame-relay bc 8000
CAn any one identify the correct Tc value. Moreover with an MTU of 1500 bytes what is the min Tc value
dgahm
Level 8
Level 8
I have a backup frame circuit so I tried it to see what the max Tc can be.
Here is the original map class:
map-class frame-relay 128CIR1
frame-relay cir 256000
frame-relay bc 32000
frame-relay mincir 128000
A 'show traffic shape' confirms an interval of 125ms.
I changed frame-relay bc to 8000 and the interval went to 31ms. I then changed it to 64000 and the interval was 125ms.
So a 7206 router running 12.2(15)T9 confirms that the max is 125ms.
6 Replies 6
stephenshaw
Hi Kumar,
use the Tc=125 ms value. Cisco divide a 1 second time period into 8 time periods, which is where the 125 ms value comes from.
Steve
Thats correct but the second example also qouted from Cisco has a Tc of 250 Msc which doent seem quite right when the documentation says 125 Msc to be maximum tc once FRTS is turned on.
Examples aren't always accurate - that's why I didn't answer it. Let Cisco answer that one.
Steve
I wonder if any Cisco techie can answer this ?
Thanks in advance
dgahm
Level 8
Level 8
gscholz
Tc of 125ms is optimum for data when you start looking at delay sensitive applications you obviously require something a lot less and also require fragmentation for large MTU packets
