Transparent Bridging and Frame-relay multipoint interface
amdcent
Anyone knows how to transparently bridge two spokes in Frame-relay network if both spokes are connected to a HUB router using a single multipoint interface.
amdcent
ssoberlik
Level 4
Level 4
The “bridge-group” command works normally under these conditions. Use the following document to guide you:
http://www.cisco.com/univercd/cc/td/doc/product/software/ios121/121cgcr/wan_c/wcdfrely.htm#37410
