09-18-2003 01:37 AM - edited 03-02-2019 10:25 AM
I have two 6509's, at seperate locations on a 622Mbps ATM WAN and they are both exhibiting the same 'errors' on the Fa0 interface of the WS-X6101-OC12-SMF ATM module.
When I session onto the WS-X6101-OC12 module and do a 'sho int' all is ok except for the FastEthernet Interface to the backplane. It shows 129/255 reliability and output errors almost matching the output packet count.
Both 6509's have the same problem. One 6509 has dual Supervisor I's with MSFC1's and the other has a dual Supervisor II's with MSFC2's.
Here is the sho int Fa0 output. Can you help confirm if this is a known problem or is it normal for this particular interface.
Many thanks,
Martin
Core_1_ATM#sho int fa0
FastEthernet0 is up, line protocol is up
Hardware is AmdFE, address is 0000.0500.0000 (bia 0000.0500.0000)
Internet address is 127.0.0.50/8
MTU 1500 bytes, BW 100000 Kbit, DLY 100 usec,
reliability 129/255, txload 1/255, rxload 1/255
Unknown duplex, Unknown Speed
Last input 00:00:00, output 00:00:00, output hang never
Queueing strategy: fifo
Output queue 0/40, 0 drops; input queue 0/75, 0 drops
5 minute input rate 3000 bits/sec, 7 packets/sec
5 minute output rate 3000 bits/sec, 7 packets/sec
138688986 packets input, 2636540910 bytes
Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
0 watchdog, 0 multicast
140552200 packets output, 1085913711 bytes, 2388 underruns
140552199 output errors, 2153 collisions, 0 interface resets
0 babbles, 0 late collision, 18528 deferred
140552199 lost carrier, 0 no carrier
09-18-2003 03:03 AM
You might want to look at the Field notices, and maybe in the Bug Tool.
http://www.cisco.com/en/US/products/hw/switches/ps700/products_field_notice09186a00801b0e00.shtml
Either way you look it doesn't look good. The reliability should not be normally like that but 255/255. So there is a problem.
Corey
09-18-2003 04:04 AM
Hi Corey,
Thanks for the info and the confirmation that it is a fault. I have already had a look at the bug tool already and did not find anything useful.
Although not a perfect match, the Field notice does look quite interesting and may be worth trying. However this as a core network in a hospital and I cannot easily get down-time so I will have to keep looking for a more specific solution for now.
Many thanks,
Martin
