viewing ports with the same vlan over multiple 3550 switches useing CMS
ppaki
I'm using CMS ( Cluster Management Suite) to manage a number of 3550 switches. I want to be able to view all ports over a number of switches that are all configured with the same vlan ID.
aashish.c
Level 4
Level 4
In CMS you will see all the switches and their ports. But there is no way or coloring scheme that will show you ports of specific vlan. you have to right click on port and check its properties like vlan, soeed duplex etc.
Kindly update for further queries...
Aashish C
I'm not to concerned about being able to view different color schemes using CMS, I was more after a report of some description showing something like, VLAN 100 on Switch1 FE0/1 and Switch2 FE0/2. Does CMS have the ability to do this, or can I do it using CLI from the Command switch
