VIP4-50 INSTALLATION PROBLEM
I need to install a new VIP4-50 on my Router 7500. This is the show version output
IOS (tm) RSP Software (RSP-JSV-M), Version 12.0(7)T, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-1999 by cisco Systems, Inc.
Compiled Mon 06-Dec-99 19:40 by phanguye
Image text-base: 0x60010908, data-base: 0x61356000
ROM: System Bootstrap, Version 11.1(2) [nitin 2], RELEASE SOFTWARE (fc1)
BOOTFLASH: GS Software (RSP-BOOT-M), Version 11.1(8)CA1, EARLY DEPLOYMENT RELEAS
E SOFTWARE (fc1)
er-prueba01 uptime is 17 minutes
System returned to ROM by reload at 17:05:21 GMT-4 Tue Aug 10 2004
System restarted at 10:43:23 GMT-4 Wed Aug 11 2004
System image file is "slot0:rsp-jsv-mz.120-7.T.bin"
cisco RSP2 (R4700) processor with 32768K/2072K bytes of memory.
R4700 CPU at 100Mhz, Implementation 33, Rev 1.0
Last reset from power-on
G.703/E1 software, Version 1.0.
G.703/JT2 software, Version 1.0.
X.25 software, Version 3.0.0.
SuperLAT software (copyright 1990 by Meridian Technology Corp).
Bridging software
TN3270 Emulation software.
Chassis Interface.
1 EIP controller (6 Ethernet).
6 Ethernet/IEEE 802.3 interface(s)
123K bytes of non-volatile configuration memory.
16384K bytes of Flash PCMCIA card at slot 0 (Sector size 128K).
8192K bytes of Flash internal SIMM (Sector size 256K).
No slave installed in slot 6.
Configuration register is 0x102
Do I have upgrade the IOS?
What should I consider beside the IOS upgrade to do a succesfully installation?
Leo
deilert
Level 6
Level 6
see this field notice
http://www.cisco.com/en/US/products/hw/routers/ps359/products_field_notice09186a0080094300.shtml
I would get off 12.0(7)T as soon as possible this was not very stabre code
