03-08-2005 12:48 PM - edited 03-02-2019 10:03 PM
I have got a switch network connected via optical fiber. We also have a couple of Cisco Aironet 350 Bridges, other Cisco switches and other brand of switches/hubs attached to the fiber network via the main fiber switches at each building. At the moment we have 3 fiber links connected as star topology, using the default VLAN.
I want to create multiple VLAN's (a vLAN for each department) and loop up all these three fiber links using the fiber connection and wireless connectivity.And then employ a router to do inter-vlan routing and this router then connected to our backbone. There are a few un-answered question that I need to answer first before I commence with this work.
1. How do I configure the Cisco switch port where Cisco 350 bridges are connected to ? Do I configure the port to be trunked or just configure it as part of a VLAN ?
2. How will I enable the Cisco 350 Bridges for VLAN and use it a means of looping (redundant link) the current fiber links ?
3. How do I configure Cisco switch port where non Cisco switches will be connected to ?
4. Any recommendation of a good router that is good for inter-vlan routing.
Hope somebody helps
Solved! Go to Solution.
03-14-2005 12:25 PM
answer : If you want to send/ recieve the more than one number of vlan traffic through bridges, you should configure the port to trunk.
To the best of my knowledge, there is no need to enable the vlan in Bridges, it simply send the trafiic across the bridges.
You shjould enable the port as trunk of 801.q.
Intervlan routing is supported from cisco 1700 series router as base model and also depends on the requirments.
03-14-2005 12:25 PM
03-14-2005 01:18 PM
Thanks. I beleive this is the info Im after
regards
03-14-2005 01:18 PM
regards
