VLAN Routing Problem
sgraham
Hi, I have a strange problem that I could do with some help on....
Setup....
2x 6500's with 1x 7206 and 1x MSFC2 router acting as VLAN routers.
5 Vlans with EIGRP.
The primary router currently is the default gateway and everything works fine, all networks are reachable.
The problem...
I wish to setup the second router as the HSRP router for the same VLAN's and for the most part this works fine. All the VLANS are mirrored addresses are all correct. Everything is working apart from one VLAN on the second router VLAN5, I setup the others no problem all can route, HSRP is working fine.
This VLAN however has a problem. The backup VLAN 5 ip address is not able to be reached from anywhere except on router itself, the primary can not ping the IP address on the backup, its almost as if its not visable. The config looks fine as the other VLANs are working on the backup and HSRP is functioning fine.
Any ideas?
28 Replies 28
I just notice something else if you do a show trunk 15/1 you get the following
Port Vlans allowed on trunk
3/1 1-1005,1025-4094
15/1 1-1005,1025-4094
Port Vlans allowed and active in management domain
3/1 1,5,10,15,20,25,30,72,99
15/1 10,15,20,30,99
Port Vlans in spanning tree forwarding state and not pruned
15/1 10,15,20,30,99
VLAN 5 isnt showing on 15/1 the trunk for the router, which must be the problem, but if I try and add it by setting the trunk command for 5 it say its already allowed for VLAN5
cat6506> (enable) set trunk 15/1 5
Vlan(s) 5 already allowed on the trunk
get on the switch and do 'set vlan 5 state active'
tduong
Can you go to session 15 and do show int vlan 5? Also, how is your layer 1 connect?
Hi, disabled and renabled VLAN5 shows as an active VLAN but still will not route.
Primary-RSM#sho int vlan 5
Vlan5 is up, line protocol is up
Hardware is Cat6k RP Virtual Ethernet, address is 0008.7cd2.5c42 (bia 0008.7cd
2.5c42)
Description: Server VLAN 5
Internet address is 172.20.152.252/21
MTU 1500 bytes, BW 1000000 Kbit, DLY 10 usec,
Last input 00:00:00, output never, output hang never
Queueing strategy: fifo
Output queue :0/40 (size/max)
5 minute input rate 3000 bits/sec, 5 packets/sec
5 minute output rate 3000 bits/sec, 3 packets/sec
5052994 packets input, 404404088 bytes, 0 no buffer
Received 5052994 broadcasts, 0 runts, 0 giants, 0 throttles
3564109 packets output, 475418401 bytes, 0 underruns
0 output errors, 12 interface resets
Just a thought, I am monkeying with another RSM issue and one suggestion that I saw was to change the number- yes whoever said that thinks that there is something with the numeric value. So can you reassign the number, say from 5 make it 17 or something and see if it makes a difference, I know makes absolutely no sense but... :)
This is an interesting problem. My gut is that this is either an IOS/CatOS bug or a switch MAC address issue. It appears that everything is configured properly on the 6500 MSFC and the 7206 router, however I don't have any info on the 6500 Supervisor CatOS config and/or version.
1) The router code on the 6500 is very old. Cisco won't even talk to you with that version of IOS [12.1(11b)E] on the MSFC. You may want to upgrade the code. My assumption is that the CatOS code is equally as out of date. There is a definite relationship between MSFC IOS and Supervisor CatOS version compatibility, so be sure to read the release notes carefully. I can make a recommendation if you send a 'show system' and 'show mod' from the Supervisor and a 'show ver' and 'show diag' from the MSFC.
2) There are a couple of configuration problems, nothing that should be causing this problem, but definitely look at the following:
- What is the native VLAN on the 7200 trunk interface? What is the result of the 'show vlans' command on the 7200 router?
- You only need to configure HSRP preemption on the neighbor that has the highest priority, by definition the lower priority neighbor can never preempt. There have been a bunch of bugs in past IOS versions with incorrectly configuring preemption on both neighbors, so avoid that configuration.
- Be very careful configuring an HSRP group number on any 6500 platform. The 6500 chassis has a limited number of MAC addresses available. The point of a group number is if you have more than one HSRP group PER INTERFACE. In the case of the MSFC/MSFC2/MSFC3, every Vlan logical interface can use the same MAC address for HSRP. This would only be a problem if you had multiple HSRP groups on ANY single interface. Just leave the HSRP group number out of the config and all will be well.
3) From the information you have provided, the MSFC virtual module 15 trunk should be forwarding Vlan 5. Note that you cannot actually configure module 15 from the Supervisor (CatOS), so your 'set trunk 15/1' command was useless. Also note that Vlan 5 will be down on the switch Supervisor if there are no ports in Vlan 5. It appears that there is a trunk configured on the switch so that shouldn't be an issue, but something to keep in mind.
4) For kicks, what is the output from the 'show spant summary' command on the switch Supervisor (CatOS)?
Hopefully that gives you some ideas, have you opened a Cisco TAC case on this issue?
Thanks for the feedback, I am wondering if this is a software issue now. If you could advise on the best release of CatOS and MSFC2 software I should upgrade to that would be great.
Below is the answers to some of your questions
Output from Show Vlans on the 7200 router...
Virtual LAN ID: 5 (IEEE 802.1Q Encapsulation)
vLAN Trunk Interface: FastEthernet2/0.5
Protocols Configured: Address: Received: Transmitted:
IP 172.20.152.253 52341237 42254486
Virtual LAN ID: 10 (IEEE 802.1Q Encapsulation)
vLAN Trunk Interface: FastEthernet2/0.10
IP 172.20.128.253 44306170 45198813
Virtual LAN ID: 15 (IEEE 802.1Q Encapsulation)
vLAN Trunk Interface: FastEthernet2/0.15
IP 172.20.136.253 8058230 8320446
Virtual LAN ID: 20 (IEEE 802.1Q Encapsulation)
vLAN Trunk Interface: FastEthernet2/0.20
IP 172.20.56.253 203046 238863
Show Spant Summ on the CatOS
cat6506> (enable) sho spant summary
MAC address reduction: disabled
Root switch for vlans: 1,5,10,15,20,25,72,99.
BPDU skewing detection disabled for the bridge
BPDU skewed for vlans: none.
Portfast bpdu-guard disabled for bridge.
Portfast bpdu-filter disabled for bridge.
Uplinkfast disabled for bridge.
Backbonefast disabled for bridge.
Summary of connected spanning tree ports by vlan
VLAN Blocking Listening Learning Forwarding STP Active
1 0 0 0 1 1
5 0 0 0 1 1
10 0 0 0 1 1
15 0 0 0 1 1
20 0 0 0 1 1
25 0 0 0 1 1
30 0 0 0 10 10
72 0 0 0 1 1
99 0 0 0 1 1
Total 0 0 0 18 18
With regard to the HSRP groups, if I dont use a group number the standbys wont match with the 7200 standby groups? I am pairing a 7200 and an MSFC.
Show Mod
cat6506> (enable) sho mod
Mod Slot Ports Module-Type Model Sub Status
1 1 2 1000BaseX Supervisor WS-X6K-SUP1A-2GE yes ok
15 1 1 Multilayer Switch Feature WS-F6K-MSFC2 no ok
3 3 48 10/100BaseTX Ethernet WS-X6348-RJ-45 yes ok
Mod Module-Name Serial-Num
1 SAD061203R1
15 SAD061300VX
3 SAL0744P0ZV
Mod MAC-Address(es) Hw Fw Sw
1 00-02-7e-38-dd-d6 to 00-02-7e-38-dd-d7 7.2 5.3(1) 6.3(3)
00-02-7e-38-dd-d4 to 00-02-7e-38-dd-d5
00-02-fc-49-fc-00 to 00-02-fc-49-ff-ff
15 00-08-7c-d2-5c-40 to 00-08-7c-d2-5c-7f 2.3 12.1(11b)E 12.1(11b)E
3 00-0e-38-b4-98-70 to 00-0e-38-b4-98-9f 6.7 5.4(2) 6.3(3)
Mod Sub-Type Sub-Model Sub-Serial Sub-Hw
1 L3 Switching Engine WS-F6K-PFC SAD061203F3 2.0
Sho Ver from MSFC
MSFC2 Software (C6MSFC2-JK2O3SV-M), Version 12.1(11b)E
I believe this is a simple fix. You don't have VLAN 1 defined on the 7206 router, so the 7206 is using the first VLAN interface as the native VLAN, i.e. VLAN 5.
Your switch is using VLAN 1 as the native VLAN.
This can be fixed by either making VLAN 5 the native VLAN on your switch or adding a subinterface to the 7206 and encapsulating VLAN 1. Be careful to NOT put an IP address on this VLAN!
This would explain why the new VLAN you added worked but you haven't been able to make VLAN 5 work.
For example: (on the 7206)
config t
interface FastEthernet2/0.1
encapsulation dot1q 1 native
end
Let me know if this works...
Got it! the 7206 did have VLAN 1 defined but the MSFC didn't. It was using VLAN5 as the native. I have made sure everything is set to 1 for the native VLANs and its now working fine.
Thanks to everyone for your help on this problem. Much appreciated.
Run "debug standby packet" and post some result that you can see related to int vlan 5 - for both MSFC and 7206 - and also set up an extended access list as follow:
access-list 150 permit IP host [source - int 5 vlan ip address from MSFC] host [destination - sub int on 7206 for vlan 5]
Run "debug ip packet 150" - after that check to see if there are any conversation between the two. Please post some message relate to Vlan 5.
Standby Debug output
00:11:07: SB10: Vl10 Hello out 172.20.128.247 Standby pri 100 ip 172.20.128.254
00:11:07: SB5: Vl5 Hello out 172.20.152.252 Speak pri 100 ip 172.20.152.254
00:11:08: SB10: Vl10 Hello in 172.20.128.253 Active pri 100 ip 172.20.128.254
00:11:09: SB5: Vl5 Hello in 172.20.152.253 Active pri 100 ip 172.20.152.254
00:11:10: SB10: Vl10 Hello out 172.20.128.247 Standby pri 100 ip 172.20.128.254
00:11:10: SB5: Vl5 Hello out 172.20.152.252 Speak pri 100 ip 172.20.152.254
00:11:11: SB10: Vl10 Hello in 172.20.128.253 Active pri 100 ip 172.20.128.254
00:11:11: SB5: Vl5 Hello out 172.20.152.252 Standby pri 100 ip 172.20.152.254
00:11:12: SB5: Vl5 Hello in 172.20.152.253 Active pri 100 ip 172.20.152.254
00:11:13: SB10: Vl10 Hello out 172.20.128.247 Standby pri 100 ip 172.20.128.254
00:11:14: SB10: Vl10 Hello in 172.20.128.253 Active pri 100 ip 172.20.128.254
00:11:14: SB5: Vl5 Hello out 172.20.152.252 Standby pri 100 ip 172.20.152.254
00:11:14: SB5: Vl5 Hello in 172.20.152.253 Active pri 100 ip 172.20.152.254
00:11:16: SB10: Vl10 Hello out 172.20.128.247 Standby pri 100 ip 172.20.128.254
00:11:16: SB10: Vl10 Hello in 172.20.128.253 Active pri 100 ip 172.20.128.254
00:11:17: SB5: Vl5 Hello out 172.20.152.252 Standby pri 100 ip 172.20.152.254
00:11:17: SB5: Vl5 Hello in 172.20.152.253 Active pri 100 ip 172.20.152.254
00:11:18: SB10: Vl10 Hello out 172.20.128.247 Standby pri 100 ip 172.20.128.254
00:11:19: SB10: Vl10 Hello in 172.20.128.253 Active pri 100 ip 172.20.128.254
00:11:20: SB5: Vl5 Hello out 172.20.152.252 Standby pri 100 ip 172.20.152.254
00:11:20: SB5: Vl5 Hello in 172.20.152.253 Active pri 100 ip 172.20.152.254un
all
00:11:21: SB10: Vl10 Hello out 172.20.128.247 Standby pri 100 ip 172.20.128.254
00:11:22: SB10: Vl10 Hello in 172.20.128.253 Active pri 100 ip 172.20.128.254
ACL Debug Ouput on VLAN5
00:12:03: datagramsize=1154, IP 0: s=172.20.152.252 (local), d=172.20.152.253 (
lan5), totlen 1154, fragment 0, fo 0, sending
00:12:03: datagramsize=1220, IP 0: s=172.20.152.252 (local), d=172.20.152.253 (
lan5), totlen 1154, fragment 0, fo 0, sending full packet
00:12:08: datagramsize=1154, IP 0: s=172.20.152.252 (local), d=172.20.152.253 (
00:12:08: datagramsize=1220, IP 0: s=172.20.152.252 (local), d=172.20.152.253 (
00:12:13: datagramsize=1154, IP 0: s=172.20.152.252 (local), d=172.20.152.253 (
00:12:13: datagramsize=1220, IP 0: s=172.20.152.252 (local), d=172.20.152.253 (
Change priority on one of the interface to higher than the other by issue a command in interface configuration: standby [group#] priority [# greater than 100] let me know if that work.
tduong
What IOS are you running on 7206 and MSFC? Does upgrade IOS is an option for you? I thought its might be something in your current IOS doesn't work righ! Please keep me update!
IOS (tm) MSFC2 Software (C6MSFC2-JK2O3SV-M), Version 12.1(11b)E, EARLY DEPLOYMEN
T RELEASE SOFTWARE (fc1)
IOS (tm) 7200 Software (C7200-JS-M), Version 12.0(5)T1, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-1999 by cisco Systems, Inc.
