VMS 2.2: Security Monitor does not work
Volker Janusch
Level 4
Level 4
after updating to IDSMDC 2.0, the sec. monitor does not work. It is impossible to activate this option from the main menue inside "VPN/security Management Solution".
The Managementcenter for IDS works fine with all new features.
VMS 2.2 works on Win 2000 SVR, SP4, engl.
Regards.
Volker
Manager DC-Networking, Automation & WLAN
Logicalis GmbH
ebreniz
Level 6
Level 6
Could you update with the latest versions of VMS, IDS MC and SEC Mon.
And go through the instructions word by word given in below document
http://www.cisco.com/univercd/cc/td/doc/product/rtrmgmt/cw2000/cw2000_b/vpnman/vms_2_2/index.htm
the newest versions are installed. Meanwhile we had opened a case because of customers high priority.
Logicalis GmbH
