voice over frame issue....
asmith
Ok, we use 3662 at hq's to connect to 1760-v's and have t-1's to each location... have a store that everything works; data, voice out, but voice in does not...
here is info from 1760:
Store129#sh dial-peer voice sum
dial-peer hunt 0
AD PRE PASS
TAG TYPE MIN OPER PREFIX DEST-PATTERN FER THRU SESS-TARGET PORT
1 pots up down 7129 0
2 vofr up up 7... 0 syst Serial0/0:0 10
3 vofr up up 5... 0 syst Serial0/0:0 10
4 vofr up up 3.. 0 syst Serial0/0:0 10
3662 shows the following for the vofr circuit:
VoiceOverFRPeer73
information type = voice,
tag = 73, destination-pattern = `7129',
answer-address = `', preference=0,
numbering Type = `unknown'
group = 73, Admin state is up, Operation state is up,
incoming called-number = `', connections/maximum = 0/unlimited,
DTMF Relay = disabled,
modem passthrough = system,
huntstop = disabled,
in bound application associated: DEFAULT
out bound application associated:
permission :both
incoming COR list:maximum capability
outgoing COR list:minimum requirement
type = vofr, session-target = `Serial1/0 129',
called number = `',
session-protocol = cisco-switched,
fax-rate = voice, payload size = 30 bytes
fax NSF = 0xAD0051 (default)
codec = g729r8, payload size = 30 bytes,
signaling-type = cas,
VAD = enabled,Voice Sequence Numbers = disabled,
voice class perm tag = `'
Connect Time = 0, Charged Units = 0,
Successful Calls = 0, Failed Calls = 5, Incomplete Calls = 0
Accepted Calls = 0, Refused Calls = 0,
Last Disconnect Cause is "2F ",
Last Disconnect Text is "no resource.",
Last Setup Time = 491492.
as you can see 3662 shows "NO RESOURCE"
1760 shows protcol donw, but have replaced FXS card at location, same issue???
where can i look?
AL
Mark Turpin
Level 5
Level 5
In the future you might want to try IP Telephony forum. :)
In the meantime, here's something to try. As 0x2F is a q.931 response I'd try a 'debug voip ccapi inout' or 'debug isdn q931' or 'debug isdn standard' and see what's going on.
Hope this helps!
-Mark
-Mark Turpin
