What cisco router part & model # do I need for 2e 10/100
kdboden
This should be a low end cisco router product with two fast ethernet interfaces. This router will connect a PBX management network to the local company lan.
jrahm
If the only requirement is two fast ethernet interfaces, do you have a l3 switch in the company lan where you could carve out a vlan for the PBX management network?
I do not have a 13 switch in the network. Right now the PBX vlan is isolated from the main network.
The only way SBC wants the pbx vlan connected is thru a router.
Tsasbrink
I believe any 2800 series will fit your requrements.
I like the 2811 most, still has a nm slot and is not too expensive for its 120kpps.
