What licence is required to use home agent on 2911
dion.stevenson1
It seems near impossible to work out what licence is required to allow the use of 'home agent' on a 2911 Router, is it part of the Base, Sec or UC?
Does anyone have an clue on where to locate this information or have a handy answer : ).
Ta
D
Terry Cheema
Are you using 2911 as CME router for agent extension with ccx or other contact center? Anyways if you want to configure telephony related feature set - you will need to UC license feature set.
-Terry
Please rate all helpful posts
vik
Assuming you are asking about the Mobile IP HA functionality you would need the Data/APP license for the same
