why we have: 6509-e and other model with VERITCAL SLOTS and also in HORZONTAL Slots ?
game123
what is the technical reason behind making 6509 in two shapes    ????
horizontal slots  vs. vertical slots ????
i need to know about it ...hence asking experts !
awaiting...
kamran.
7 Replies 7
Marwan ALshawi
the 6509-v-e:
provides front-to-back airflow that is optimized for hot and cold aisle designs in colocated data center and service provider deployments and is compliant with Network Equipment Building Standards (NEBS) deployments.
http://www.cisco.com/en/US/products/ps9306/index.html
hope this help
I have idea on the reason for vertical slot.... but .............on cisco data sheets.
i am not truly able to fidn the difference?
ok...can u pls tell me diff. b/w the following 3 models?
6509-E
6509-V-E
6509-NEB-A
awaiting !
6509-V-E
The "V" stands for Vertical.
ok as i menionted above the diffrence between virtical and horizantal that vertical:
V-E and NEB-A are both Virtical but:
Cisco Catalyst 6509-V-E chassis is part of the enhanced Cisco Catalyst 6500 series of switches, offering enhanced benefits over the Cisco Catalyst 6509-NEB-A chassis. Table 1 compares the Cisco Catalyst 6509-NEB-A to the Cisco Catalyst 6509-V-E chassis.
feature Comparison Between Cisco Catalyst 6509-NEB-A and Cisco Catalyst 6509-V-E Chassis
Feature
Bandwidth Capacity per Slot
40 Gbps
80 Gbps
System Bandwidth Capacity
720 Gbps
1440 Gbps
Cable Management
Category 5e and fiber
Category 5e, Category 6, Category 6a and fiber
Supported Maximum System Power
4500W
14500W
Standby Fabric Hot Sync (Supervisor Engine Switchover)
1.5 s
50 ms
Number of EoBC Channels
NEBS L3 Compliant
Yes
Yes
http://www.cisco.com/en/US/prod/collateral/switches/ps5718/ps708/product_bulletin_cisco_catalyst_6509_enhanced_vertical_chassis.html
hope this help
if helpful rate
please let us know if this answered your question !
Disclaimer
The   Author of this posting offers the information contained within this   posting without consideration and with the reader's understanding that   there's no implied or expressed suitability or fitness for any purpose.   Information provided is for informational purposes only and should not   be construed as rendering professional advice of any kind. Usage of  this  posting's information is solely at reader's own risk.
Liability Disclaimer
In   no event shall Author be liable for any damages whatsoever (including,   without limitation, damages for loss of use, data or profit) arising  out  of the use or inability to use the posting's information even if  Author  has been advised of the possibility of such damage.
Posting
As the other posters have already described, you have the "ordinary" 6500s and the versions with NEBS certifications.
What might not be as clear, although this can be seen in the stats of one of Marwanshawi's posts, is Cisco has upgraded both versions to allow for more power within the chassis and to support more bandwidth to line cards.
So you "ordinary" 6500s:
6509 (original) to 6509-E (enhanced)
and the NEBS versions:
6509-NEB-A (original) to 6509-V-E (enhanced)
As to why the NEBS versions use vertical cards rather the horizontal cards, it might be it made it easier to meet NEBS certification or it might be Cisco just wanted them to look different or somewhere in between.
Except for the NEBS certifications, a 6509-NEB-A is sort of equivalent to a 6509 while a 6509-V-E is sort of equivalent to a 6509-E.
Renan Abreu
Basically for different cooling
