06-20-2014 08:12 AM - edited 03-03-2019 07:28 AM
Hi! I would like to know if WS-3850-24T-S is supported by LAN Management Solution (LMS). If yes, in which version of LMS. Thanks
06-20-2014 05:07 PM
06-21-2014 01:25 AM
Hi Leo
thanks for reply. Unfortunately, my model WS-3850-24T-S is not listed in table of your link. Do you have other compatability links?
Thanks.
06-22-2014 11:07 PM
For more specific detail you should share sysObjectID of your device. Poll you device for snmp Object SysObjectID (1.3.6.1.2.1.1.2) and share the result.
Its the unique identifier to know which version of LMS supports that specific device.
-Thanks
Vinod
06-22-2014 11:40 PM
Dear Vinod
thank you very much for your reply. Is it possible to know sysObjectID without polling of device? For example, from labels on WS-3850-24T-S? Problem is that device just delivered to customer and is not connected to network.
Thanks.
06-23-2014 01:18 AM
You can try to use the following command and share output :
show snmp sysobjectid
-Thanks
Vinod
**Encourage Contributors. RATE Them.**
06-23-2014 05:16 AM
Dear Vinod
unfortunately, cabinet with WS-3850-24T-S already on the customer's stock and I have no chances to do your procedure in nearest time. May I ask you if exactly WS-3850-24T-S is principally supported by LMS (without clarification of version) and where it is stated.
Many thanks in advance.
06-25-2014 02:11 AM
Dear Vinod
