3620 boot system flash
admin_2
Level 3
Level 3
I have a 3620 with IOS 11.2(18)P,looking to boot from the second flash file (an IOS upgrade). When doing the "boot system flash:filename" command, it wants the hostname or IP address of where to get the config file from. Putting nothing in results in the command line having an all broadcast address tagged on the end. How can I load the startup config file from nvram?
Not applicable
instead of typing
'boot system flash:filename' type
'boot system flash filename'
