Auto backup using Kron method
Faisal Khan
Level 2
Level 2
Today, i configure Kron method for auto backup on my one switch 2960G version 12.2 but it can't work, below are the configurations we have
_______________________________________________________________
#kron policy-list SaveConfig
#cli copy system:/running-config tftp://192.168.0.209/Meeting_sw.txt
#kron occurrence SaveConfigSchedule
at 11:00 fri recurring
#policy-list SaveConfig
Meeting_SW#sh kron schedule
Kron Occurrence Schedule
saveconfigschedule inactive, will run again in 0 days 22:44:42 at 11:00 on Fri
______________________________________________________________________
Testing of TFTP server;
Meeting_SW#show run | redirect tftp://192.168.0.209/RBackup.cfg
can anyone help me on this issue.....
Faisal Naseem Khan
8 Replies 8
cadet alain
kron doesn't support interactive command so you should replace
by
cli show running-config | redirect tftp://192.168.0.209/Meeting_sw.txt
Alain
Thanks Cadet, its working with cli show running-conf....
Can u explain one more thing...
how to configure auto schedule backup on ASA 5550...
take a look here:https://supportforums.cisco.com/thread/2135564
Alain
Hi Faisal,
Can you please help me with the command to get output for multiple show commands in a single text file like show vlan brief, show interface trunk, show ip eigrp neighbor and so on. Thanks.
Another way to backup your config would be the archive-function. That would probably be the right tool for the job.
Don't stop after you've improved your network! Improve the world by lending money to the working poor:
http://www.kiva.org/invitedby/karsteni
If you found this post helpful, please give it Kudos. If my answer solves your problem, please click Accept as Solution so others can benefit from it.
 Hi Everyone,
I created a piece of technical documentation that should help everyone out. I have automated daily backups for running-configs and startup-configs. Please let me know what you think.
https://www.slideshare.net/TravisKench/automate-cisco-switch-configuration-backups-with-kron
Travis
Travis
That's really helpful. Thanks for sharing.
Quick question: Is there a way to add the timestamp in the .txt file name?
D00677281
Frequent Visitor
Frequent Visitor
Yes, please.  Im trying to keep multiple versions of a config.  Date and time stamp would be great.  That way it doesnt over write the same file every time.  Ive tried using the $h-$t variables.  but that doesnt seem to do anything for Cisco IOS XE.
Thanks!
