cat 4006 problem. urgent help needed
haseeb_eng
Gigabit card is installed in the server which is is connected to supervisor engine 2 uplink module through fiber cable which is 1/2 port in the 1st module of the cat 4006 . It was working fine before suddenly the traffic stopped coming from the switch side to the server . I can see on the windows that the network is up and it is sending traffic but it is not recieving traffic Also on the switch the LED is not blinking on the uplink fiber port. Here are the configurations of the switch and RSM . Please recommend me what could be the possible actions for the problem
sh conf
#version 6.1(1)
#system web interface version(s)
#test
#system
set system name 4006-switch
#frame distribution method
set port channel all distribution mac both
#snmp
set snmp community read-only xxxx
set snmp community read-write xxxx
set snmp community read-write-all xxxx
set snmp rmon enable
set snmp trap enable module
set snmp trap enable chassis
set snmp trap enable repeater
set snmp trap enable vtp
set snmp trap enable auth
set snmp trap enable ippermit
set snmp trap enable vmps
set snmp trap enable entity
set snmp trap enable config
set snmp trap enable stpx
--More-- set snmp trap enable syslog
set snmp trap 192.168.100.254 xxxx
set snmp trap 192.168.100.130 xxxx
#vtp
set vtp domain PAF
set vlan 1 name default type ethernet mtu 1500 said 100001 state active
set vlan 2 name Internal_LAN type ethernet mtu 1500 said 100002 state active
set vlan 3 name External_LAN type ethernet mtu 1500 said 100003 state active
set vlan 1002 name fddi-default type fddi mtu 1500 said 101002 state active
set vlan 1004 name fddinet-default type fddinet mtu 1500 said 101004 state active stp ieee
set vlan 1005 name trnet-default type trbrf mtu 1500 said 101005 state active stp ibm
set vlan 1003 name token-ring-default type trcrf mtu 1500 said 101003 state active mode srb aremaxhop 7 stemaxhop 7 backupcrf off
#ip
set interface sc0 1 192.168.100.100/255.255.255.0 192.168.100.255
set interface sl0 down
255.0.0.0 0.255.255.255
set interface me1 down
set ip route 0.0.0.0/0.0.0.0 192.168.100.50
#syslog
set logging console disable
set logging level cops 2 default
#set boot command
set boot config-register 0x2
set boot system flash bootflash:cat4000.6-1-1.bin
#mls
set mls nde disable
#port channel
set port channel 1/1-2 21
set port channel 4/1-2 31
set port channel 4/3-6 32
set port channel 4/7-10 33
set port channel 4/11-14 34
set port channel 4/15-18 35
set port channel 3/1-4 186
#http configuration
set ip http server enable
#module 1 : 2-port 1000BaseX Supervisor
set vlan 2 1/1
set port trap 1/1-2 enable
set port name 1/1 Suprt_Agrdept
set port name 1/2 Paaf-Main
set port channel 1/2 mode off
#module 2 : 34-port 10/100/1000 Ethernet
set vlan 2 2/1-4,2/6,2/8-33
set vlan 3 2/5,2/7,2/34
#module 3 : 34-port Router Switch Card
set vlan 2 3/1-17,3/19,3/21-22,3/24,3/26,3/28-34
set vlan 3 3/18,3/23,3/25,3/27
set port speed 3/26 100
set port trap 3/1-34 enable
set port name 3/19 Agrsrv17
set port name 3/20 main_SNMP
set port name 3/21 Agrsrv
set port name 3/23 Mproxy_Ext
set port name 3/24 Mproxy_Int
set port name 3/25 R2509
set port name 3/26 R2620
--More-- set port name 3/27 SAT
set trunk 3/1 on dot1q 1-1005
set trunk 3/2 on dot1q 1-1005
set spantree portfast 3/19 enable
set port channel 3/1-2 mode on
#module 4 : 18-port 1000BaseX Ethernet
set port trap 4/1-18 enable
set port name 4/1 Maintenance
set port name 4/2 Agriculture_Block
set port name 4/3 Main_Store
set port name 4/4 Vice_GM
set port name 4/5 Plant_ResearchDpt
set port name 4/6 AMG_Office
set port name 4/7 Admin
set port name 4/8 Forgin_Relations
set port name 4/9 Financial_Dep
set port name 4/10 Farm_House
set port name 4/11 Water_Soil
set port name 4/12 Plant_ResearchSec
set port name 4/13 Archieve
set port name 4/14 Agriculture
set port name 4/15 Statistical
set port name 4/16 Animal_Products
set port name 4/17 Chairman_House
set port name 4/18 Decoration_Dept
set trunk 4/1 on dot1q 1-1005
set trunk 4/2 on dot1q 1-1005
set trunk 4/3 on dot1q 1-1005
set trunk 4/4 on dot1q 1-1005
set trunk 4/5 on dot1q 1-1005
set trunk 4/6 on dot1q 1-1005
set trunk 4/7 on dot1q 1-1005
set trunk 4/8 on dot1q 1-1005
set trunk 4/9 on dot1q 1-1005
set trunk 4/10 on dot1q 1-1005
set trunk 4/11 on dot1q 1-1005
set trunk 4/12 on dot1q 1-1005
set trunk 4/13 on dot1q 1-1005
set trunk 4/14 on dot1q 1-1005
set trunk 4/15 on dot1q 1-1005
set trunk 4/16 on dot1q 1-1005
set trunk 4/17 on dot1q 1-1005
set trunk 4/18 on dot1q 1-1005
#module 5 empty
#module 6 empty
end
4006-switch> (enable) sh module 1Mod Slot Ports Module-Type Model Sub Status
1 1 2 1000BaseX Supervisor WS-X4013 no ok
Mod Module-Name Serial-Num
1 JAB050308VM
Mod MAC-Address(es) Hw Fw Sw
1 00-04-dd-5b-8e-00 to 00-04-dd-5b-91-ff 1.3 5.4(1) 6.1(1)
PAAF_4006> (enable) sh port 1/2 2 Port Name Status Vlan Level Duplex Speed Type
1/1 Suprt_Agrdept notconnect 2 normal full 1000 1000-LX/LH
1/2 Paaf-Main notconnect 1 normal full 1000 1000BaseSX
2/1 connected 2 normal full 1000 1000BaseSX
2/2 connected 2 normal full 1000 1000BaseSX
2/3 connected 2 normal a-full a-100 10/100BaseTX
2/4 notconnect 2 normal auto auto 10/100BaseTX
2/5 connected 3 normal a-full a-100 10/100BaseTX
2/6 connected 2 normal a-full a-100 10/100BaseTX
2/7 connected 3 normal a-full a-100 10/100BaseTX
2/8 connected 2 normal a-full a-100 10/100BaseTX
2/9 connected 2 normal a-full a-100 10/100BaseTX
2/10 notconnect 2 normal auto auto 10/100BaseTX
2/11 connected 2 normal a-full a-100 10/100BaseTX
2/12 notconnect 2 normal auto auto 10/100BaseTX
2/13 connected 2 normal a-full a-100 10/100BaseTX
2/14 notconnect 2 normal auto auto 10/100BaseTX
2/15 connected 2 normal a-full a-100 10/100BaseTX
2/16 connected 2 normal a-full a-100 10/100BaseTX
2/17 connected 2 normal a-full a-100 10/100BaseTX
2/18 notconnect 2 normal auto auto 10/100BaseTX
2/19 notconnect 2 normal auto auto 10/100BaseTX
--More-- 2/20 notconnect 2 normal auto auto 10/100BaseTX
2/21 notconnect 2 normal auto auto 10/100BaseTX
2/22 notconnect 2 normal auto auto 10/100BaseTX
2/23 notconnect 2 normal auto auto 10/100BaseTX
2/24 connected 2 normal a-full a-100 10/100BaseTX
2/25 connected 2 normal a-full a-100 10/100BaseTX
2/26 notconnect 2 normal auto auto 10/100BaseTX
2/27 connected 2 normal a-full a-100 10/100BaseTX
2/28 notconnect 2 normal auto auto 10/100BaseTX
2/29 connected 2 normal a-full a-100 10/100BaseTX
2/30 notconnect 2 normal auto auto 10/100BaseTX
2/31 notconnect 2 normal auto auto 10/100BaseTX
2/32 connected 2 normal a-full a-100 10/100BaseTX
2/33 notconnect 2 normal auto auto 10/100BaseTX
2/34 connected 3 normal a-full a-100 10/100BaseTX
3/1 connected trunk normal full 1000 No Connector
3/2 connected trunk normal full 1000 No Connector
3/3 notconnect 2 normal auto auto 10/100BaseTX
3/4 notconnect 2 normal auto auto 10/100BaseTX
3/5 connected 2 normal a-full a-100 10/100BaseTX
3/6 connected 2 normal a-full a-100 10/100BaseTX
3/7 connected 2 normal a-full a-100 10/100BaseTX
3/8 notconnect 2 normal auto auto 10/100BaseTX
--More-- 3/9 notconnect 2 normal auto auto 10/100BaseTX
3/10 notconnect 2 normal auto auto 10/100BaseTX
3/11 connected 2 normal a-full a-100 10/100BaseTX
3/12 connected 2 normal a-half a-10 10/100BaseTX
3/13 connected 2 normal a-full a-100 10/100BaseTX
3/14 connected 2 normal a-full a-100 10/100BaseTX
3/15 connected 2 normal a-full a-100 10/100BaseTX
3/16 connected 2 normal a-full a-100 10/100BaseTX
3/17 connected 2 normal a-full a-100 10/100BaseTX
3/18 notconnect 3 normal auto auto 10/100BaseTX
3/19 Agrsrv17 connected 2 normal a-full a-100 10/100BaseTX
3/20 main_SNMP notconnect 1 normal auto auto 10/100BaseTX
3/21 Agrsrv connected 2 normal a-half a-10 10/100BaseTX
3/22 connected 2 normal a-full a-100 10/100BaseTX
3/23 Mproxy_Ext connected 3 normal a-full a-100 10/100BaseTX
3/24 Mproxy_Int notconnect 2 normal auto auto 10/100BaseTX
3/25 R2509 notconnect 3 normal auto auto 10/100BaseTX
3/26 R2620 notconnect 2 normal half 100 10/100BaseTX
3/27 SAT notconnect 3 normal auto auto 10/100BaseTX
3/28 notconnect 2 normal auto auto 10/100BaseTX
3/29 connected 2 normal a-full a-100 10/100BaseTX
3/30 notconnect 2 normal auto auto 10/100BaseTX
3/31 notconnect 2 normal auto auto 10/100BaseTX
--More-- 3/32 notconnect 2 normal auto auto 10/100BaseTX
3/33 notconnect 2 normal auto auto 10/100BaseTX
3/34 notconnect 2 normal auto auto 10/100BaseTX
4/1 Maintenance connected trunk normal full 1000 1000BaseSX
4/2 Agriculture_Block connected trunk normal full 1000 1000BaseSX
4/3 Main_Store connected trunk normal full 1000 1000BaseSX
4/4 Vice_GM connected trunk normal full 1000 1000BaseSX
4/5 Plant_ResearchDpt notconnect 1 normal full 1000 1000BaseSX
4/6 AMG_Office connected trunk normal full 1000 1000BaseSX
4/7 Admin connected trunk normal full 1000 1000-LX/LH
4/8 Forgin_Relations connected trunk normal full 1000 1000-LX/LH
4/9 Financial_Dep connected trunk normal full 1000 1000-LX/LH
4/10 Farm_House connected trunk normal full 1000 1000-LX/LH
4/11 Water_Soil connected trunk normal full 1000 1000-LX/LH
4/12 Plant_ResearchSec connected trunk normal full 1000 1000-LX/LH
4/13 Archieve connected trunk normal full 1000 1000-LX/LH
4/14 Agriculture connected trunk normal full 1000 1000-LX/LH
4/15 Statistical connected trunk normal full 1000 1000-LX/LH
4/16 Animal_Products connected trunk normal full 1000 1000-LX/LH
4/17 Chairman_House connected trunk normal full 1000 1000-LX/LH
4/18 Decoration_Dept connected trunk normal full 1000 1000-LX/LH
--More-- PAAF_4006> (enable) sh port 1/2Port Name Status Vlan Level Duplex Speed Type
Port Security Violation Shutdown-Time Age-Time Max-Addr Trap IfIndex
1/2 disabled shutdown 0 0 1 enabled 5
Port Num-Addr Secure-Src-Addr Age-Left Last-Src-Addr Shutdown/Time-Left
1/2 0 - - - - -
Port Send FlowControl Receive FlowControl RxPause TxPause Unsupported
admin oper admin oper opcodes
1/2 desired off off off 0 0 0
Port Status Channel Admin Ch
Mode Group Id
1/2 notconnect off 21 0
--More-- Port Align-Err FCS-Err Xmit-Err Rcv-Err UnderSize
1/2 - 0 0 0 0
Port Single-Col Multi-Coll Late-Coll Excess-Col Carri-Sen Runts Giants
1/2 0 0 0 0 0 0 0
Last-Time-Cleared
Sun Nov 3 2002, 20:00:58
RSM configuration
sh run
4006_RSM>#sh running-config
Building configuration...
Current configuration:
version 12.0
no service pad
service timestamps debug uptime
service timestamps log uptime
hostname 4006_RSM>
ip subnet-zero
interface Port-channel10
no ip address
no ip directed-broadcast
hold-queue 300 in
interface Port-channel10.1
encapsulation dot1Q 1 native
ip address 192.168.100.50 255.255.255.0
no ip redirects
interface Port-channel10.2
encapsulation dot1Q 2
ip address 192.168.1.200 255.255.255.0
no ip redirects
interface Port-channel10.3
encapsulation dot1Q 3
ip address x.x.x.x 255.255.255.240
no ip redirects
interface FastEthernet1
no ip address
interface GigabitEthernet1
no ip address
channel-group 10
interface GigabitEthernet2
no ip address
channel-group 10
interface GigabitEthernet3
no ip address
no negotiation auto
channel-group 10
interface GigabitEthernet4
no ip address
no negotiation auto
channel-group 10
router rip
passive-interface FastEthernet1
network 192.168.1.0
network 192.168.100.0
ip classless
ip route 192.168.2.0 255.255.255.0 x.x.x.x
arp 127.0.0.2 0004.dd5b.8e00 ARPA
snmp-server community xxxx RO
snmp-server community xxxx RW
line con 0
transport input none
line aux 0
line vty 0 4
password telnet
login
end
4006_RSM>#
jcmartin
Since you don't indicate that any configuration changes have been made to either your switch or your server, and the sh port commands indicate that port 1/2 is in a notconnect state, I'm guessing that it's a hardware issue. First make sure your GBIC is seated, or reseat it. Then check your fiber cables. I've seen untouched fiber cables just go bad. Make sure they are plugged in tightly. If so, replace the fiber. If that doesn't fix it, try replacing the GBIC. If all that fails, it might be a bad NIC in the server.
If you have a spare gig port in the switch, try reconfiguring that port as port 1/2 and move the GBIC to that port to rule out an issue with the Sup module.
