CCNAv7 Lab results
Kintech
Hi there,
a few days ago I started introducing myself with the first course for CCNAv7. All is fine so far but I would like to have solutions for the labs. Especially longer taking labs, like "11.9.3 Packet Tracer - VLSM Design and Implementation Practice", for instance. If I work on it then from the beginning I don't know whether I go into the right direction. At the end I can "Check results" but still i don't know what the correct values would be if my solution wouldn't. It would be better to self-value at the beginning already. Additionally, there are textual answers which cannot be checked automatically.
How are other students following that?
If that is not the right place to post please tell me as well.
Kintech
Martin L
I don't think this is right place as this forum is for technical issues;  you can try CLN if you doing self-study on your own; or net academy site or via your school/instructor.
VLSM is advanced subnetting topic usually at the middle of ccna courses.
Regards, ML
**Please Rate All Helpful Responses **
