Choosing Frame-relay, HDLC or PPP
astrand
I have been trying to find information about advantages and disadvantages of the different data-link layer protocols on WAN links. I documents describing each of the protocols, but none comparing them.
I would be very helpful if someone could point me to any documents describing this or post comments into this forum.
Thanks in advance!
Harald
pmajumder
Level 3
Level 3
Generally speaking they can be differentiated as follows - I am sure there's much more it:
Okay as you know the most common types of WAN communication links in use today are:
1) Leased Dedicated Point-to-Point permanent
circuits: A organization that leased the circuit &
is paying for the full dedicated bandwidth (such
as a T1) 24 hours a day, 7 days a week whether
they actually use the full bandwidth or not. PPP
and HDLC are commonly used over dedicated leased
lines. HDLC is commonly used between Cisco
routers, where's PPP is more suitable if
interoperability is desired.
2) Frame Relay Packet-Switched circuits:
Packet-switched networks enable orgs to
dynamically share the cloud, and the available
bandwidth and it is possible to only pay for the
bandwidth you need (CIR). Frame Relay is
considered a cost effective replacement for leased
line services such as PPP & HDLC
Pradeep
Thank you very much for your answer!
I am actually only interested in the encapsulation for dedicated leased lines. I have one customer using frame-relay also for a dedicated network and I am trying to understand the benifits of this compared to Cisco HDLC and PPP. I know that PPP can do authentication and as far as I know Frame-relay and PPP can do QoS, but not HDLC. Is that correct?
That's right, HDLC will not support authentication as each vendor's implementation of the protocol is different - Cisco's implementation adds an extra field in the frame that allows it to support different L3 thats encapsulated in it. Normal HDLC does not have it (also the reason for the interoperability issue).
As for QoS support I believe you could do some rtp header compression on hdlc links, but I don't believe you can do any LL queueing as you can on PPP & FR links. So if you are doing VOIP, you are better of using PPP or even FR.
If cost is not a factor, then the only reason to use HDLC is that it is easy to configure - you practically do nothing :-)
Hope this helps somewhat..
Pradeep
