Cisco Packet Tracer 7.2.1.0218 Not able to create network objects on firewalls
techfour2020
I'm currently using Cisco Packet Tracer 7.2.1.0218
When using any of the Cisco ASA firewalls 5505 or 5506 I'm not given the option to add a new object-group network. Is only showing the option of object-group service.
Is there a limitation on the commands that can be run in Cisco ASA when using Packet Tracer?
Alan Ng'ethe
Level 3
Level 3
Yes, unfortunately. One is not able to run all commands when using packet tracer, and I believe this is one of them.
You may want to try GNS3 if you aren't already using it. It does take some work to set up but in the end it is worth it.
Remember to rate helpful posts and/or mark as a solution if your issue is resolved.
Thanks for the response. I downloaded and installed the GNS3. I watched a video that mentions I will need the images for the devices. For example, to use Cisco ASA 5505 I will need the iso image from Cisco.
How can I get these images for free?
Hi @techfour2020 ,
Your friend Google should be able to help you.
