Datacenter build - Network design needs checking
paul.monaghan
Community Member
Hi Guys,
If anyone can find the time to check the network layout attached with this would be much appreciated. This design is regarding a new redundant DC being built (hypathectically only) but i need to know if i've connected this in the right way/ if its possible with the equipment listed.
Here is the equipment being used
Core/Aggregation Switches: WS-C6506-E x2
Access switches:  WS-C4948-10GE-S x3
Terminal server: CISCO2811-16TS x1
WAN FireWalls: ASA5540-BUN-K9 x2
Appreciate any and all feedback and aplologies for my lack of knowledge here
Paul
Marwan ALshawi
Hi there
i think yo need to use in the DC collapsed core/aggregation model and put in VSS mode i mean the 65K
http://www.cisco.com/en/US/products/ps9336/index.html
multie home each of the access switches and the firewalls to the VSS pair using dot1q etherchannel channge usingmultichassis ether channel MEC
configure failover between the firewalls and configure HSRP between the WAN routers for active/standby WAN access
see bellow:
hope this helps
Marwan ALshawi
Hi there
see bellow:
hope this helps
Thanks a lot marwanshawi, this has really helped. Appreciate your time to look at this
happy to help and thanks for rating
