Eigrp Neighbor not on common subnet for VlanXXX
dmoorefnlc
Ok, got my Eigrp static route redistributed. But now Eigrp on site 2 complaining that every vlan is not "common" on both sites.
Vlan192 links Site1 to Site2
Site1 EigrpConfig:
router eigrp 700
redistribute static metric 10000 1000 255 1 1500
network 10.20.0.0 0.0.255.255
network 192.168.0.0 0.0.3.255
no auto-summary
eigrp stub connected static
nterface Peers Un/Reliable SRTT Un/Reliable Flow Timer Routes
Vl2 0 0/0 0 0/10 0 0
Vl20 0 0/0 0 0/10 0 0
Vl22 0 0/0 0 0/10 0 0
Vl26 0 0/0 0 0/10 0 0
Vl28 0 0/0 0 0/10 0 0
Vl30 0 0/0 0 0/10 0 0
Vl32 0 0/0 0 0/10 0 0
Vl34 0 0/0 0 0/10 0 0
Vl36 0 0/0 0 0/10 0 0
Vl38 0 0/0 0 0/10 0 0
Vl40 0 0/0 0 0/10 0 0
Vl255 0 0/0 0 0/10 0 0
Vl192 1 0/0 9 0/10 50 0
Site2 posted next
psprice
It means that the two EIGRP routers have seen each others hello packets on the VLAN but that they are in different subnets - both routers VLAN interfaces need to be in the same subnet.
Phil
how can I put do this? The common interface they share is in the same subnet, 192.168.0.0/22. Site1 is 192.168.0.2, Site2 is 192.168.3.6, bothe /22.
But the other interfaces naturally are different IP subnets. Site 1 is 10.20.0.0/16, site2 10.120.0.0/16.
Is there a way to only get hello's sent from the 192.168.0.0/22 interfaces, not from the other interfaces?
thanks
I used the passive-interface vlan command. on my site2 for all vlan's but 192.
That has stopped the warnings. Is this an acceptable "fix" to this?
dmoorefnlc
Here is site2
router eigrp 700
network 10.120.0.0 0.0.255.255
network 10.223.2.204 0.0.0.0
no auto-summary
no eigrp log-neighbor-changes
no eigrp log-neighbor-warnings
Interface Peers Un/Reliable SRTT Un/Reliable Flow Timer Routes
Vl42 0 0/0 0 0/10 0 0
Vl50 0 0/0 0 0/10 0 0
Vl120 0 0/0 0 0/10 0 0
Vl192 1 0/0 1303 0/10 6512 0
Enable of eigrp log-neighbor-warnings gives the following on site2:
(Default-IP-Routing-Table:700): Neighbor 10.120.2.3 not on common subnet for Vlan50
IP-EIGRP(Default-IP-Routing-Table:700): Neighbor 192.168.3.9 not on common subnet for Vlan2
IP-EIGRP(Default-IP-Routing-Table:700): Neighbor 192.168.0.182 not on common subnet for Vlan2
IP-EIGRP(Default-IP-Routing-Table:700): Neighbor 10.120.50.3 not on common subnet for Vlan2
ColoVpn6509>(config-router)#
seems router is at a war with itself. only 192.168.0.2 isn't native to this 6509.
