Error: "% Flow Record: Failed to field add: Failed to validate Unsetting Public:behaviour" when adding "collect interface output" on netflow config
regis.pierquin
When trying to add this netflow config, I get an error on the last line "collect interface output":
Config:
flow record MY-RECORD
description MY Flow Record
match routing vrf input
match ipv4 tos
match ipv4 protocol
match ipv4 source address
match ipv4 destination address
match transport source-port
match transport destination-port
match interface input
match interface output
match flow direction
collect ipv4 dscp
collect counter bytes
collect counter packets
Error:
The same happens when I try to add "collect interface input"
johnsmunoz
You probably have a flow monitor setup somewhere with a line
record MY-RECORD
try doing a
NO record MY-RECORD
add then do a
and then re-enable the flow record.  at least that's what worked for me.
steveng777
It looks like match "interface input/output" are mutually exclusive with "collect interface input/output". You can only have one in the flow record block. At least what's what I noticed.
