How to enable ssh and telnet on a 1841
insccisco
can anyone please help me in enabling ssh access to my 1841 router?
I am trying to connect to the router from a host sitting on the inside interface of the router
thanks
2 Accepted Solutions
Angel
The security feature set does support SSH so that is one requirement taken care of.
If you had the ability to get in through SSH but now do not, I wonder if there is some error message that is generated when you attempt SSH? This might help us understand what the problem is, and therefore what the solution should be.
I can think of two things that could prevent SSH access:
1) if someone configured the vty lines with transport input and did not include SSH as one of the transports. If you can post the configuration of the vty lines we can see if this is the case.
2) if the crypto key was changed or removed, or if the router name was changed (I just recently ran into the effect of changing the router name - which is to invalidate the crypto key which then prevents SSH access). To make sure this is not the problem I suggest that you do the following:
verify that the router is configured with a valid hostname and a valid domain name
reboot the router
config term
crypto key gen rsa gen mod 1024
ip ssh version 2
exit
Then see if SSH works again.
Rick
Rick
Angel
The command transport input on the line vty specifies which protocols will be accepted as input to the vty lines (which are what is used for remote access). If the command specifies only SSH then SSH is the only protocol that will be accepted (telnet will fail) and if the command specifies both SSH and telnet then both SSH and telnet will be permitted and both protocols will work.
Rick
Rick
9 Replies 9
Richard Burts
Angel
The first step in enabling SSH is to find whether you have a feature set on your router that supports it. SSH requires crypto support and not all feature sets provide this. (Note that this is not a what version issue but a feature set within a version issue)
Assuming that you have (or get) a feature set that does support crypto the next step is to generate RSA crypto keys. To be able to generate crypto keys the router must be configured with a non-default router name and a domain name (these are used to assign an identity to the keys being generated). So after configuring hostname and domain use the crypto key generate command in config mode to generate the keys.
That pretty much enables SSH. Depending on the version of IOS you may have an option whether to run version 1 or version 2 of SSH.
Rick
Rick
Hi Rick,
my IOS version is 12.4. I also have the security feature set with this 1841. Somewhere along the configuration, the ability to get in thru ssh got lost. When I first configured the router, I was able to use it, but I must have done something wrong afterwards.
Can you send me the exact commands to do this?
thanks
Angel
reboot the router
config term
ip ssh version 2
exit
Rick
Rick
Hi Rick,
I tried doing all your steps and I ended up with:
line vty 0 4
transport input telnet ssh
But the funny thing is that it worked. I did the "crypto key gen rsa gen mod 1024" and it seems that it did the trick.
Now, when I do a "sh ip ssh" at the # prompt, I get
SSH enabled - version 1.99
Authentication timeout: 120 secs; Authentication retries: 3
Again, I am able to get in thru ssh from the inside subnet.
I wish I knew more about all these commands I typed; so if there are any readings about it, can you please forward them to me?
thanks again
dbakula01
1) router must have hostname and a DNS domain.
2) aaa new-model
3) cry key generate rsa
4)line vty 0 4
!--- Prevent non-SSH Telnets.
5)transport input ssh
I see. My router has a hostname and the domain name still at the default (yourdomain.com)
I was able to fix it thanks to help from here.
My line vty 04 shows the following:
line vty 0 4
Comparing this to what you suggested, your has it as "transport input ssh" and mine has the "telnet" word in it.
What is the difference and is this telling the router?
thanks
Angel
Rick
Rick
Rick,
again, you are the man. I like the way you are clearing things out for me... you're making it simple :)
thanks
Angel
I am glad that we have been able to help. Thank you for rating posts. It makes the forum for useful for participants when we can see topics which have had helpful answers.
I encourage you to continue your participation in the forum.
Rick
Rick
