Bookmark
Subscribe
1438
LAN - WAN management
4tts
hi, i have a LAN of about 60 computers and a four frame-relay WAN links connect to the head office. Could you please suggest a solution which can allow me to manage / monitor and report on the users, and devices on the Local Area Network and the WAN devices, thanks
drolemc
Level 6
Level 6
That is never an easy question to answer. It is really a question of your preferences and what you would like to do. Anyways, if you ask me, for managing LANs, the CiscoWorks LAN Management Solution (LMS) would be a good option (http://www.cisco.com/en/US/products/sw/cscowork/ps2425/index.html). For the WAN end of things, you could consider using CiscoWorks Routed WAN Management Solution (http://www.cisco.com/en/US/products/sw/cscowork/ps2426/index.html). HTH
