Level 2 and Level 3 Switches
jacqueline10
If I am configuring a LAN and WAN do I need to enter the gateway ip address on both Switches, may layer 2 Switch is already connected to the layer 3 Switch?
thisisshanky
Level 11
Level 11
You need to add a default route pointing to your gateway. On the layer 2 switch (depending on set based or ios based) the command for the gateway varies. This gateway address configured on the l2 switch is only used for switch generated traffic ( such as you telnet from the switch to an address outside the subnet of the ip address of the switch). To configure a l2 default gateway on cat 6000 the command is,
set ip route default [metric] [primary]
On a 2900, you can use the IOS based command "ip default-gateway "
Sankar Nair
UC Solutions Architect
Pacific Northwest | CDW
CCIE Collaboration #17135 Emeritus
