Managing Cisco switch 2948G using AdventNet WebNMS.
arunelr
my task is to manage cisco's 2948G switch using our Network Management System.I have decided to use "CISCO-STACK-MIB" for this purpose.Is my assumption correct?Switch has 48 10/100Mbps ports and 2 modular GigaEthernet ports with GBIC.But it does not tell anything about number of chassis,modules.There are specific cisco mibs for some switches.But i could not find one for this switch.Can i use CISCO-STACK-MIB and if yes what will be the number of modules,slots.Kindly analyse and reply me.Moreover which switch can be used so that i can achieve both Gigabit Ethernet speed and VLAN provisioning?
amritpatek
Level 6
Level 6
Yeah you can use CISCO-STACK-MIB. As per the document given below the CISCO-STACK-MIB is supported on all Catalyst 2900 switches.
Workgroup MIB Reference
http://www.cisco.com/en/US/products/hw/switches/ps606/products_configuration_guide_chapter09186a008007f1a3.html
To know more on the modules of Catalyst 2900 series Switches refer to the Product Documentation.
