planning rendundancy setting
hi all, now i'm design a network like this :
2 switch Catalyst 6500
4 switch Catalyst 4000 (redundant)
Catalyst 2950 (24 port) (with redundant connection), each switch has 2 Connection from two different Catalyst 4000.
Personal Computer
with this network, i need to setup Vlan, maybe more than one in each cat2950.
there have problems with this setting? and if number of nodes grows rapidly, can i make hops/new connection (cat2950 to cat2950) but still provide maximum Cat5e bandwith for each user.
thank's.
CSCO10662744_2
It looks like there's enough redundency in your physical design and I don't see a problem w/ it.
It's the logical topology that you need to watch out for (ether-channel vs single link, RSTP vs PVST, etc)
What did you mean by "can i make hops/new connection (cat2950 to cat2950) "??
You wanna daisy-chain 2950s together? I'd avoid it.
CSCO10662744_2
