priority-queue out and 3750
ciscoforum
Does 3750 switch still need command "priority-queue out"? I noticed when I apply " auto qos voip cisco-phone", it doesn't auto generate "priority-queue out" any more. I know this command is useful in 3550 to prioritize the voice traffic.
pradeepde
Level 5
Level 5
This release contains these new switch features or enhancements:
Quality of service (QoS) egress priority queue on a port. Shaped round robin (SRR) services the priority queue until it is empty before servicing the other three queues. You enable the egress priority queue by using the priority-queue out interface configuration command.
QoS Differentiated Services Code Point (DSCP) transparency allows the user to prevent the switch from rewriting the DSCP field in the user IP packet when QoS is enabled.
http://www.cisco.com/univercd/cc/td/doc/product/lan/cat3750m/12114ax/ol464603.htm
