Problem With HP Superdome connection
cpiombi
Our HP super dome crashed and when it came back up it could not get to any thing on the network, the network into which this connects is a Cat6513 with a 48 port Copper Eht blade, and a Vlan to which the port is configured. I could ping any thing else on the same vlan and the vlan interface gateway. As alway the system guys are blaming the network, any ides or thoughts?
can you check the IP settings for the Superdome server, that is, does it have the correct default gateway filled in ?
GP
