Problems with CVSM (a cause of browser incompatibility?)
MhnsITSolutions
I have some problems with the Visual Switch Manager
(CVSM) on a WS-C2916M-XL Catalyst Switch. Since its
old Hardware (and dont support IOS 12.x afaik) i only
have the idea that i run in Java/Browser trouble. The
Switch run with the latest available IOS for this old
"4 MB" Switch:
Version 11.2(8.11)SA6, MAINTENANCE INTERIM SOFTWARE
Maybe its simple incompatibility to the current
browsers? I tested the CVSM from a Windows XP (IE)
and a Suse Linux Client with (Firefox,Mozilla,Opera
and Konqueror. I also tryed new and old Java versions.
Sometimes the on the "Visual Switch Manager Home"
Site the applet dont load. Sometimes it load and
the navigation on top wont work correctly.
Only With Opera the applet on the "Visual Switch
Manager Home" start/default Page and the navigation
works fine.
The "Switch Network View" never works. The applet
simple gangs or show "applet crashed" as text there
in the middle of the gray field.
I tryed a lot for troubleshoot but i am out of
ideas. Can anybody here help me maybe?
By the way ... on cisco´s website at this link:
http://www.cisco.com/univercd/cc/td/doc/product/lan/c2900xl/29_35sa6/scg/kiconfig.htm#xtocid2727842
It shows a "System Time Management" on the webinterface.
In my webinterface (CVSM) i dont have this area under the "System"
Navigation. There are only System Configuration, IP Management
SNMP Configuration and ARP Table available for me. Any idea why?
Thank you!
MhnsITSolutions
Nobody here who can help with my problem(s) ?
Thanks ...
