09-08-2014 09:56 AM - edited 03-03-2019 07:35 AM
I have a issue with a router 7606, specifically with fan module, the LC go down because it does have sufficiently cooling , I changed the Fan module, the IOS, The power supply, and I still have the same issue, Besides the Router does not show the inventory or PID for module fan,
logg" system minor alarm on operating fan count"
Someone knows what could be happening,
09-08-2014 09:47 PM
Check this:
Can you try this;
7606-01#show environment status fan-tray 1
fan-tray 1:
fan-tray 1 type: FAN-MOD-6SHS
fan-tray 1 mode: Auto
fan-tray 1 fan-fail: OK
7606-01#show power
Fan Type Watts A @42V State
1 FAN-MOD-6SHS 180.18 4.29 OK............................ FAn try
If above doesnt work then try the below link:
https://supportforums.cisco.com/discussion/10824271/7606-s-and-fan-module-6shs-version-1
inayath
*Plz dont forget to rate if this info is helpfull.
09-10-2014 10:14 AM
thanks
I did it, but i still have the same issue, upgrated the ios, changed fan module, but it is not working,
will be the chassis?
