09-30-2003 11:49 PM - edited 03-02-2019 10:42 AM
I have an Industrial client who want to replace their optical hubs with switches. They have an fibre backbone and run ethernet over fibre to the PC's.
However they also run process control electronics using Siemens SINEC H1 protocol.
Does anyone know if Cat switches can support this protocol and if so is any special config or Cat OS required?
Martin
Solved! Go to Solution.
10-01-2003 02:37 AM
The Siemens SINEC H1 protocol is a ISO OSI layer 4 protocol. It runns over the ethernet data link layer, so no configuration is required for catalyst switches.
Cheers,
Liviu
10-01-2003 02:37 AM
Cheers,
Liviu
10-01-2003 04:46 AM
Thank you!
