spanning tree problem
MARCELO MATURO
Level 3
Level 3
There are 2 catalyst 5500 with 2 trunks, one an etherchannel (isl), the other an ATM OC3 ( lane trunk).
One of the switches is the root bridge of the tree ( it has priority 1, the other 5).
One of the vlan is blocking in the channel port, is forwarding through the ATM trunking in the root bridge switch.
How is possible that there would be blocking ports in the root bridge?
This is the show for the vlan that is blocking:
CATALYST1> (enable) sh spantree 5
VLAN 5
Spanning tree enabled
Spanning tree type ieee
Designated Root 00-02-18-ca-00-00
Designated Root Priority 1
Designated Root Cost 37
Designated Root Port 2/1
Root Max Age 20 sec Hello Time 2 sec Forward Delay 15 sec
Bridge ID MAC ADDR 00-02-18-ca-00-04
Bridge ID Priority 1
Bridge Max Age 20 sec Hello Time 2 sec Forward Delay 15 sec
Port Vlan Port-State Cost Priority Fast-Start Group-Method
1/1-2 5 blocking 2 0 disabled channel
2/1-2 5 forwarding 19 32 disabled redundancy
3/1 5 forwarding 100 32 disabled
3/15 5 forwarding 19 32 disabled
3/17 5 forwarding 19 32 disabled
3/18 5 forwarding 19 32 disabled
3/20 5 forwarding 19 32 disabled
3/22 5 forwarding 100 32 disabled
3/23 5 forwarding 19 32 disabled
3/24 5 forwarding 19 32 disabled
4/1 5 forwarding 5 32 disabled
5/1 5 forwarding 19 32 disabled
5/2 5 forwarding 19 32 disabled
5/7 5 forwarding 19 32 enabled
5/8 5 forwarding 19 32 disabled
5/12 5 forwarding 19 32 disabled
5/19 5 forwarding 19 32 disabled
5/23 5 forwarding 19 32 disabled
CATALYST1> (enable)
Thanks.
Marcelo
steve.barlow
Level 10
Level 10
This switch is not root for vlan 5, hence he is blocking. This switch sees the root on port 2/1-2 (and the root has a different mac than the local switch). The blocked port is 1/1-2. Ports 1/1-2 are blocked, ports 2/1-2 are forwarding. The other end of the link is root, and it is still in forwarding state on both trunks. If the secondary switch didn't block one end, there would be a loop.
This is the potential loop without the block:
switchAport1/1-2 -(x)------switchBport1/1-2
switchAport2/1-2 -------switchBport2/1-2
(where x is the blocked ports)
Steve
Steve, You say is true. But see something:
This is the output for sh modules:
Mod MAC-Address(es) Hw Fw Sw
1 00-02-18-ca-00-00 to 00-02-18-ca-03-ff 3.8 5.1(2) 5.1(1)
2 00-60-3e-cc-33-bc 2.4 1.3 11.3(8)WA4(11a) 3.2(13)
3 00-01-63-53-a2-88 to 00-01-63-53-a2-9f 3.3 4.3(1) 5.1(1)
4 00-e0-1e-91-de-2c to 00-e0-1e-91-de-2d 7.7 20.18 12.0(5)
5 00-04-28-77-fd-f8 to 00-04-28-77-fe-0f 1.1 4.5(2) 5.1(1)
Mod Sub-Type Sub-Model Sub-Serial Sub-Hw
1 EARL 1+ WS-F5511 0019515344 1.1
CATALYST1> (enable)
The system mac is the same the is showed for the root bridge in vlan 5.
And this switch is the only with priority 1 en the lan.
See the show spantree for the other sw:
C_5509_GRANJA_SOLIS> (enable) sh spantree 5
VLAN 5
Designated Root Cost 36
Designated Root Port 4/1
Bridge ID MAC ADDR 00-02-18-ca-f8-04
Bridge ID Priority 5
1/1-2 5 forwarding 2 32 disabled channel
2/1 5 forwarding 10 32 disabled
2/2 5 forwarding 10 32 disabled
2/3 5 forwarding 10 32 disabled
2/4 5 forwarding 13 32 disabled
2/5 5 forwarding 10 32 disabled
2/7 5 forwarding 10 32 disabled
2/9 5 forwarding 10 32 disabled
2/10 5 forwarding 10 32 disabled
3/1 5 forwarding 10 32 disabled
3/2 5 forwarding 10 32 disabled
3/3 5 forwarding 10 32 disabled
3/4 5 forwarding 10 32 disabled
3/6 5 forwarding 10 32 disabled
3/7 5 forwarding 10 32 disabled
3/8 5 forwarding 10 32 disabled
3/9 5 forwarding 10 32 disabled
3/12 5 forwarding 10 32 disabled
3/13 5 forwarding 19 32 disabled
3/14 5 forwarding 19 32 disabled
3/19 5 forwarding 19 32 disabled
3/21 5 forwarding 19 32 disabled
3/22 5 forwarding 19 32 enabled
4/1-2 5 forwarding 18 32 disabled redundancy
5/1 5 forwarding 5 32 disabled
I don´t understand what is happening.
Marcelo
Your right this looks strange.
CATALYST1 1/1-2 -x--------1/1-2 C_5509_GRANJA_SOLIS
CATALYST1 2/1-2 ----------4/1-2 C_5509_GRANJA_SOLIS
CATALYST1 sees mac 00-02-18-ca-00-00 on port 2/1 and C_5509_GRANJA_SOLIS sees it on 4/1. Yet that mac is on mod 1 of CATALYST1. Is this only for vlan 5 or other vlans?
They are both in the same vtp domain and have both trunk ends for both trunks set as the same trunking mode?
I am leaning towards the lane trunk or a bug as the fault.
Steve
Both swtiches are in the same vtp domain. Both trunk ends are set as ISL. For the other vlans don't happen the same. For example vlan 1:
CATALYST1> (enable) sh spantree 1
VLAN 1
Designated Root Cost 0
Designated Root Port 1/0
Bridge ID MAC ADDR 00-02-18-ca-00-00
1/1-2 1 forwarding 2 0 disabled channel
2/1-2 1 forwarding 19 33 disabled redundancy
3/24 1 forwarding 19 32 disabled
4/1 1 forwarding 5 32 disabled
5/3 1 forwarding 19 32 disabled
5/10 1 forwarding 19 32 disabled
5/11 1 forwarding 19 32 disabled
the other:
C_5509_GRANJA_SOLIS> (enable) sh spantree 1
VLAN 1
Designated Root Cost 12
Designated Root Port 1/1-2
Bridge ID MAC ADDR 00-02-18-ca-f8-00
1/1-2 1 forwarding 12 32 disabled channel
2/1 1 forwarding 10 32 disabled
2/6 1 forwarding 10 32 disabled
2/12 1 forwarding 10 32 disabled
3/4 1 forwarding 10 32 disabled
3/7 1 forwarding 10 32 disabled
3/10 1 forwarding 10 32 disabled
3/16 1 forwarding 19 32 disabled
3/17 1 forwarding 19 32 disabled
3/20 1 forwarding 19 32 disabled
3/23 1 forwarding 19 32 disabled
4/1-2 1 blocking 18 32 disabled redundancy
5/1 1 not-connected 5 32 disabled
