Unable to browse web console using browser
pandeyrajiv23
I am connected to Cisco WS-C3750G-48TS. I am new to this field. When I am browsing the ip address in my nrwoser, I am  able to access the home page. However, when I click on the web console, I am getting an error of "the webpage cannot be found". I am able to access the switch using telnet. Can somebody help me with commands or ideas to solve this error. Any answer will be appreciated.
Martin Hruby
Please make sure you configured "ip http server" in the global configuration mode.
You also need to configure authentication for the web service, using either AAA, the enable password or local authentication, for example:
username test privilege 15 password test
ip http authentication local
You should now be able to login to the switch using a web console, unless there are some security features (i.e. access-lists) preventing access to TCP port 80.
This discussion has been reposted from Additional Communities to the Other Network Infrastructure Subjects community.
