V.35 cable length
a.elsherif
Dear Colleagues
I have a Cisco standard cable (smart serial, V.35 3m) i want to extend this cable, can i have the pin assigment and the max length i can extend the cisco standard cable with.
Best Regards
Abdel Fattah Elsherif
lgijssel
Level 9
Level 9
The cable-pinout can be found in the following URL:
http://www.cisco.com/en/US/products/hw/routers/ps259/prod_technical_reference09186a00800a8585.html
If I am not mistaken, the maximum length is 15 meters.
Leo
The length of the cable depends on the data rate you want. 15 meters is for 2Mbps, if you only have a T1 or less you could extend the cable a little farther. There is a chart which shows the detail at the following link.
http://www.cisco.com/en/US/products/hw/accessor/ps107/products_tech_note09186a0080093cee.shtml
