3550 problem
lagartijo
Hi, i´m using a 3550 - 12G switch router as a core switch at my companys office, i have configure a series of vlan and the switch is making intervlan routing by default, the problem is that a i need to setup per vlan security, the classic extended acl´s are not an option because the scenario needs to have all vlan outbound traffic open and the inbound traffic restricted with just some ports open (www, ftp, Databases, ssh, etc.), i have tryed with reflexive acl but 3550 doesn´t support this feature neither CBAC and this is an urgent case. What can I do??
1 x Cisco 3550 - 12G (EMI) (core - InterVLAN Routing)
10 x Cisco 2950-SX Access Switch
3 x Cisco 2950-T Access Switch
a.kiprawih
Level 7
Level 7
I think Reflective ACL is not available for Cat3550-12G.
Chechk the IOS feature you're looking at:
http://tools.cisco.com/Support/Fusion/index.do
*CCO login required
The nearest hit is Time-based ACL, but probably not but relevant. Anyway, you can try to play around with it and see if you can make use of the time restriction features to allow/control any incoming access (via address), e.g allow any incoming access/traffic/addresses for maximum hours (based on time), and only deny incoming for 1 min (just an idea). Other options probably not really useful.
Hope this helps.
Rgds,
AK
epang
Look into VACLs which is programmable in a 3550..
