08-19-2003 02:39 PM - edited 03-09-2019 04:28 AM
What is the procedure for the installation of 3DES activation key on Cisco PIX 525 series?.
Thanks in advance.
R.a.M.
Solved! Go to Solution.
08-19-2003 03:43 PM
If you're running 6.2 and above then just use the activation-key command.
If you're running 6.1 and below, you have to upgrade the code via the console, and after the code has been loaded it'll ask you if you want to enter in a new activation key.
To be honest, it's probbaly easiest to upgrade to 6.2 and above and then just use the command.
See http://www.cisco.com/warp/public/110/upgrade.shtml for details.
08-19-2003 03:43 PM
08-19-2003 08:57 PM
Ok!, thanks for your help. His explanation was very clear.
R.a.M.
